Audio Art & Design
Forum rules
Foto Album
Re: Audio Art & Design
Post by sn » 06 Sep 2017, 18:17
Post by sn » 10 Sep 2017, 12:30
Post by sn » 13 Sep 2017, 20:32
Post by sn » 15 Sep 2017, 12:01
Post by sn » 17 Sep 2017, 00:42
Post by sn » 19 Sep 2017, 16:54
Post by sn » 25 Sep 2017, 14:58
Post by sn » 27 Sep 2017, 20:54
Post by sn » 27 Sep 2017, 21:39
Crescendo Mark II
Specifications:
Design 3-way transmission line
Frequency Response 20 Hz to 30 kHz (+/- 3 dB)
Crossover 3rd order (Linkwitz/Riley)
Tweeter 2" horn loaded ribbon
Midrange 2 5" underhung voice coil drivers
Woofer 2 8" underhung voice coil drivers
Impedance 6 Ohms nominal
Efficiency 90 dB SPL @ 1 meter
Power Handling 50-200 wpc RMS
Dimensions 50" H x 11" W x 17" D
1270mm H x 279mm W x 432mm D
Weight 125 lbs (62.5 Kg) each
:sign http://www.acousticzen.com/products/lou ... orstanding
Post by sn » 01 Oct 2017, 15:48
Post by sn » 05 Oct 2017, 00:58
Post by sn » 12 Oct 2017, 14:38
Post by sn » 12 Oct 2017, 19:23
Type: 3 way bass-reflex floor standing loudspeaker
Drivers: Two 61/2‘’ (16.5cm) Flax woofer with NIC motor
61/2‘’ (16.5cm) Flax midrange with TMD suspension and NIC
motor 11/16’’ (27mm) ‘IAL3’ pure Beryllium inverted dome tweeter
Sensitivity: (2,83V/1m) 91dB
Frequency Response: (+/-3dB) 35Hz - 40kHz
Low Frequency Point: (- 6dB) 29Hz
Nominal Impedance: 8Ω
Minimum Impedance: 3.1Ω
Recommended Amplifier Power: 40 - 300W
Crossover Frequency: 260Hz - 2,700Hz
Dimensions: (H x W x D) 441/64 x 1825/32 x 1241/64 (1,118 x 477 x 321 mm)
Net weight: (with front grille) 77.2lbs (35kg)
Packaging dimensions: (HxWxD) 4939⁄64 x 2711⁄64 x 1617⁄32’’ (1,260 x 690 x 420mm)
Total weight: (including packaging) 88.2lbs (40kg)
:sign https://www.focal.com/en/home-audio/hig ... /kanta-no2
Post by sn » 14 Oct 2017, 17:22
Post by sn » 17 Oct 2017, 11:59
