Raidho Acoustics D-5.1
Post by sn » 11 Sep 2016, 17:01
The Raidho Acoustics D-5.1 is a true 3-way Raidho Diamond Driver loudspeaker. It has two dedicated 115 mm Diamond mid-range and four 8” Diamond bass drivers. The two mid-range drivers allow for unprecedented dynamic headroom lowers compression and vanishing low distortion figures. The four 8” bass drivers have grip, slam and extend deeper than the music on the recording itself. When you emerge yourself in the physical presence of the D-5 something magical happens: It simply reveals the inner substance of your music with a realism and naturalness that will leave you breathless. The D-5.1 is a truly unique musical performer and is for those, who really enjoy spending time and effort setting up their system and finding superb matching components, the closest you will ever get to bring “in real life” music experiences into your listening room.
Size (WxHxD): 250 x 1950 x 680 mm (250 x 2085 x 815 mm incl. feets)
Weight: 165 Kg
Freq. reponse 25 Hz – 50 KHz
Impendance: >6 ohm
Sensitivity: 89 dB 2.83 V/m
Crossover: 3 kHz 2. and 4 order
Enclosure: Vented design Port in front panel
Drive units: 1 sealed ribbon tweeter 2 100 mm diamond mid-range drivers 4 160 mm diamond bass drivers
Finish: Black piano All possible paint colors Walnut burl veneer
Amplification: >50 W (Though we have seen excellent results with small tube amplifiers)
:sign http://raidho.dk/product-detail/d-5/
