EAC problem
Ras
EAC problem
Post by Ras » 21 Oct 2008, 14:22
Instaliram pre neki dan EAC i već nakon prvih podeševanja mi bude jasno zbog čega ovaj softver nije na mom računaru još od ranije (probao već sa istim simptomima).
Naime, EAC ne vidi niti jedan od mojih optičkih drajvova!
Da ironija bude veća, video je dva virtualna drajva. Napominjem da se situacija ponovila i nakon deinstalacije programa za virtualne drajvove i nove instalacije EAC.
Niti jedan drugi softver, a ni WinXP nemaju problem da vide i koriste bilo koji od ovih drajvova.
Eni ajdias?
Drajvovi su u sledećoj konfiguraciji prikačeni na Abit NF7S matičnu ploču: DVD-RW Pioneer na jedan IDE kanal kao master, dok su druga dva na drugom IDE kanalu, CD-RW Sony kao master i DVD-R Sony kao slave.
Re: EAC problem
Post by ninja » 21 Oct 2008, 14:50
Procitaj ovo:
http://rip59.dk/EACFlac/EACFlacRipping.html
Obrati paznju na:
Download the file wnaspi32.dll, after downloading the ZIP file place the wnaspi32.dll file found in the ZIP file in the EAC program folder (C:\Program Files\Exact Audio Copy). After installing EAC, Flac and copying the dll-file, reboot the computer.
Under the setup of the EAC program you will need information about the read sample offset correct value for the CD-drives in your system, you'll find them here.
Step 9:
Problem? Check out that the wnaspi32.dll file are at place as described above in the EAC folder.
Ras
Re: EAC problem
Post by Ras » 21 Oct 2008, 15:30
ninja wrote: Obrati paznju na:
Ovo je ekspresno rešilo problem i bez ponovne instalacije i bez restarta računara.
Hvala!
