Trends Audio PA-10 Tube Headphone/Pre Amplifier
Post by sdanicic » 18 Dec 2008, 09:32
Trends PA-10 Tube Headphone/Pre Amplifier released -
High end but not priced audio product.
After a fairly long and extensive beta-test period, the Trends
PA-10 Tube Headphone/Pre Amplifier is finally released. It
represents a major new technology of Hi-Fi products, containing
a long list of unique features:
- the innovative circuit design of low voltage hybrid (tube/transistor)
pre-amp to provide audiophile quality sound, compact size, and
easy/safe DIYer accessibility
- pure class-A circuit to provide the best sound performance
- support both 6DJ8/6922 series and 12AU7 series tubes by simply
switching the jumpers. DIYers can easily change their both series
tubes to enjoy the fun.
- ONE bi-triode 6DJ8/6922 or 12AU7 tube as voltage amplification and
TWO MOSFETs as output driver which perform the warm, comfortable
tube sound and in addition, guarantee the high fidelity & sufficient
driving power to the next power amplifier stage.
- provide all functions of headphone amplifier, pre-amplifier and
phono pre-amplifier
- provide TWO sets of switching audio inputs. Besides the normal CD
input, the Phono input with higher gain is provided for small output
turntable or PC sound card. No separated phono pre-amplifier
is required.
- Besides the normal audio output in the back panel, ONE headphone
output in the front to drive even high-impedance audiophile-grade headphones
- compact design (mini-size & light weight), suitable for hi-fi room,
living room, sleeping room or even right beside your laptop computer.
- TWO precise screw-driving potentiometers for professional audiophiles
to adjust the tube’s bias voltage to guarantee the best working point
for different tubes.
- require just a single +24V power supply ONLY, besides the bundled
AC adaptor, audiophiles can apply all other power supply with the
same spec., e.g. lead-acid batteries.
- a specially designed AC power adaptor with extra low ripple & noise
for Hi-Fi device is bundled for continuous power supply
- separate pre-amp unit & power adaptor to minimize interference and
flexible to apply other power sources, e.g. lead-acid battery.
Re: Trends Audio PA-10 Tube Headphone/Pre Amplifier
Post by sdanicic » 26 Dec 2008, 09:49
Par slika kao ilustracija.
Prema obecanju iz Trends Audia, mogu da ocekujem svoj primerak pocetkom februara 2009.
Post by DejanM » 26 Dec 2008, 10:50
Ovo meni lici na SE design sa jednom triodom po kanalu ... Stoga je od prilicnog znacaja kako je uradjeno napajanje od 24V koje se dovodi spolja. To dalje znaci da treba uraditi jedno dobro napajanje u posebnoj kutiji .... Racunaj na taj dodatni trosak ...
Post by sdanicic » 26 Dec 2008, 10:53
Pa evo neka prvo stigne, zamenicu odmah original lampu sa EH 6922, pa cemo da ostavim malo da se usvirava jedno nedelju dana i onda da vidim ima li smisla ici u upgrade :)
Post by DejanM » 26 Dec 2008, 11:29
Smisla sigurno ima jer je kod SE topologije kolo napajanja spojeno sa kolom signala. To je jedan od razloga zasto je potrebno imati jako "cisto" napajanje sa sto je moguce manje peakova, harmonika, ... To se cuje ... mnogo vise nego kod recimo PP designa. Zato su napajanja kod SE uredjaja cesto daleko slozenija nego sam pojacavacki stepen (koji je u principu jako jednostavan).
Jedna od varijanti ti je da pokusas sa baterijskim napajanjem ali da napravis i punjac za te baterije. Moram ti stoga reci jednu tuznu (ili veselu - sve zavisi) vest: igrarije tek pocinju ...
P.S. Kod ovakvih pojacalaca se cesto stavlja i regulator nakon ispravljackog dela napajanja. E a to ti je posebna prica ... Videti pod Naim ...
Boogie Woogie
Post by Boogie Woogie » 26 Dec 2008, 12:35
napajanje, obično il "čisto", obrni okreni, sve to zvuči isto..
:P
Post by DejanM » 26 Dec 2008, 13:21
Boogie Woogie wrote:napajanje, obično il "čisto", obrni okreni, sve to zvuči isto..
:P
Sa ovim se, na zalost, ne bih mogao sloziti .... narocito ne kada je o SE tipu uredjaja rec ...
Boogie Woogie
Post by Boogie Woogie » 26 Dec 2008, 13:44
uređaji ovi, oni..sve to meni isto zvoni...
\:D/
Post by sdanicic » 14 Jan 2009, 11:49
Postar upravo doneo paket iz dalekog Hong Konga :)
Post by sdanicic » 15 Jan 2009, 14:44
Par slika sa police nakon raspakivanja paketica :)
blood&brain
Post by blood&brain » 15 Jan 2009, 18:35
:P
Jasno.
Boogie, baci pogled na "onaj" forum. Ja sam tamo jednom pokusao (mislim da je pokusaj bio uspesan :) ) da objasnim znacaj dobrog napajanja.
http://www.hifi-forumi.com/forum/viewto ... a&start=45
Edit: xexexe, tek sada vidim da si ti bio pokretac teme :!:
Dakle, tranzistori u izlazu i jesu i nisu toliko bitni. Razlike su u <> u nijansama. Recimo, slusao sam jednom fenomenalno pojacalo sa 2N3055 u izlazu (DIY klon Bedinija).
Ali, napajanje razdvaja uredjaje po klasama, tu nema dvojbe.
Post by DejanM » 15 Jan 2009, 20:58
B&B,
Procitah onu analogiju sa buretom koje se puni i prazni ... Nisam siguran da si na to mislio - jesi li ? Tu analogiju je na onom forumu napisao neko ciji je pseudonim krivimozak (koji naziv :-k ](*,) :ovo ) - da li si to ti ?
Ta analogija sa strujom i vodom ... Na drugoj godini elektrotehnike, u predmetu koji se nekada zvao Regulacije ili Sistemi automatskog upravljanja, na pocetku knjige koju je ako se dobro secam napisao Milic Stojic, postoji analogija izmedju strujnog kola sa otpornikom, kondenzatorom i kalemom, jednog hidraulicnog sistema (sa vodom) i jednog mehanickog sistema sa oprugama. U sustini sva ta tri, na prvi pogled potpuno razlicita sistema su imali potpuno identicnu diferencijalnu jednacinu koja ih je opisivala. To se nalazilo na samom pocetku knjige i ukazivalo je na jednu veoma bitnu cinjenicu: da je jedan te isti sistem moguce implementirati sa potpuno razlicitim tehnologijama. Sa druge strane bilo je vazno naglasiti postojanje matematickih modela i njihove validnosti u analizi tehnickih sistema.
Hocu samo da kazem da to koriscenje analogija ima i svoj dublji smisao i da nije bez veze. Stvarno je moguce napraviti pojacalo pomocu bureta i vode koje ce u principu da radi potpuno istu stvar ... verovatno se ne bi mnogo ni razlikovalo od onoga sto si ti ili krivimozak napisao ... :good
blood&brain
Post by blood&brain » 16 Jan 2009, 12:22
Nemam pojma koji ti je taj krivimozak :)
Moj nick je isti kao i ovde samo preveden na srpski :wink:
Isti je i avatar...
Slicna prica postoji i kod Nelson Passa od pre deset godina, mislim da je zflazar dao link u onoj temi.
Ipak, ideja za tu pricu nije potekla od Nelsona.
Nije ni iz knjiga :) Ja nisam studirao elektroniku, elektrotehniku ili nesto slicno.
Na "onom" forumu nisam hteo da kazem odakle mi cela ta prica jer tamo ima mnogo faca koje bi to okarakterisala kao "q...cenje" ili preterivanje.
Ovde su ozbiljni ljudi pa mislim da nije problem da "odam tajnu" - radi se o tome da imam starijeg brata koji je vrhunski strucnjak za raketnu tehniku i radarsku tehnologiju (i cevnu i poluprovodnicku). Sustinu one price sam cuo od njega pre vise od 20 godina kada sam pravio pojacalo, tacnije zapoceo da ga pravim po principu kako mali Perica zamislja DIY a onda se on iskidao od smeha kada je video sta i kako radim, odrzao mi predavanje o osnovnim principima po kojima rade pojacala, dao na citanje i proucavanje jednu knjigu koja je cela bila posvecena samo jednom - lemljenju. Naucio me je i ono sto su u knjizi propustili - da se tranzistori na hladnjak ispravno stezu jedino kilo kljucem. Mnogi ce verovatno reci da je to preterivanje, al' moje pojacalce radi bez greske 23 godine. :-"
Post by DejanM » 16 Jan 2009, 14:26
Sorry za konfuziju oko nickname-a ... I cestitke za pojacalo koje radi 23 godine ... :mr
Sta da ti kazem ... popricaj sa bratom i kada budes krenuo da pravis novo pojacalo - blago tebi kad imas starijeg brata koji se razume u elektroniku ... :D
blood&brain
Post by blood&brain » 16 Jan 2009, 16:32
DejanM wrote:... blago tebi kad imas starijeg brata koji se razume u elektroniku ... :D
Pa i nije. On stvarno ima elektroniku u malom prstu ali na pojacala (bio to cak i Krell) gleda po principu - igraju se deca. Ja sam misio da se folira dok nisam otisao kod njega na radar i video poluprovodnicke diode velicine bejzbol palice.
Inace, vec godinama ga molim da mi sklepa neki cevni izlaz, al' ga jednostavno mrzi... izgovor mu je da je on to prerastao odavno :)
