SqueezBox Touch
SqueezBox Touch
Post by ninja » 27 Jun 2009, 20:03
Squeezebox Touch
Logitech® Squeezebox™ Touch. The color touch-screen Wi-Fi music player that lets you discover a world of music. Listen to your personal digital music collection, new music from online music services*, and thousands of Internet radio stations—all through your stereo. A 4.3-inch color touch screen makes it easy for anyone to use.
Audio formats: • MP3, FLAC, WAV, AIFF, WMA, Ogg Vorbis, AAC, Apple Lossless • WMA Lossless, APE, MPC and WavPack supported through transcoding • Some formats may require additional software installation Internet radio • Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams Wireless interface • True 802.11g wireless networking • Support for 802.11b and 802.11g routers and access points • One-touch setup (with compatible WPS-supporting routers) • Supports WPA Personal, WPA-2AES, and 64/128-bit WEP encryption Ethernet interface • Connects to any 100 Mbps or 10 Mbps network (with Auto MDX) General: • USB host connector for accessing music and photos via USB drive or USB key • SD card slot for music and photos • Supports sampling rates up to 24 bit / 96 kHz • Stereo analog (RCA), headphone jack, digital optical, and digital coax output • 4.3-inch 24-bit color LCD with capacitive touch screen • Ambient light sensor to adjust display brightness according to environment • Infrared proximity sensor to detect presence
Re: SqueezBox Touch
Post by sdanicic » 29 Jun 2009, 09:09
A koliki je sampling rate za Squeezebox Duet?
Re: SqueezBox Touch
Post by ninja » 29 Jun 2009, 09:39
sdanicic wrote:A koliki je sampling rate za Squeezebox Duet?
Mislim da je isto kao i sa SB3_> Sample rates: 44.1Khz, 48Khz
Re: SqueezBox Touch
Post by ninja » 05 Sep 2009, 18:43
U prodaji negdje oko decembra. Oni koji su ga testali su zadovoljni sa ekranom i mogucnoscu prikljucivanja HDa direktno preko USBa i tako spasava nas sto nemamo NAS ili ne zelimo da imamo stalno ukljucen PC.
blood&brain
Re: SqueezBox Touch
Post by blood&brain » 05 Sep 2009, 19:52
Cena?
Moze li se nekako uporediti sa ovim
http://www.pakom.com/KatalogProizvoda/O ... ra=9019609
Da li se kvalitet zvuka sa WD uredjaja moze nositi sa doticnim squeezeboxom?
Kako trenutno resavam ovaj problem
http://www.audiohard.com/phpBB3/viewtop ... 580#p12580
postavlja se pitanje - ima li uopste smisla ulagati u konekciju PCja sa televizorom kada
vec postoje dedicated uredjaji koji pruzaju i kvalitet i komfor?
Re: SqueezBox Touch
Post by DejanM » 06 Sep 2009, 11:15
Squeezebox je sprava koja je posvecena audio reprodukciji. Uredjaj sa linka koji si postovao je u stanju da obradi i sliku i da se poveze sa video panelima. U tome je osnovna razlika izmedju njih. Znaci ako si zainteresovan samo za audio, onda SB ... a ako ti treba i video, onda je ta druga sprava moguca varijanta.
blood&brain wrote: Kako trenutno resavam ovaj problem
To je stvar preference. Takodje zavisi puno i od toga gde ti se nalazi PC ... kakav ti je zahtev po pitanju komfora .... Ja licno pokusavam da PCs, LapTops itd. drzim sto dalje od HiFi sistema odnosno od TVa ... Ali to je neki moj licni stav.
Re: SqueezBox Touch
Post by DejanM » 06 Sep 2009, 11:19
Odlicno izgleda ovaj SB Touch ! U poredjenju sa njim SB Duet izgleda zastarelo. USB home opcija je isto tako sjajna stvar za one koji nece da se zezaju sa WLANom. Jedino je steta sto podrzava "samo" 24/96 ....
blood&brain
Re: SqueezBox Touch
Post by blood&brain » 06 Sep 2009, 14:49
DejanM wrote: Uredjaj sa linka koji si postovao je u stanju da obradi i sliku i da se poveze sa video panelima. U tome je osnovna razlika izmedju njih.
E, da mi ti nisi rekao ja to ne bih znao :D
Deki, ipak nisam toliki Mujo...
Ovo je krucijalno pitanje - Da li se kvalitet zvuka sa WD uredjaja moze nositi sa doticnim squeezeboxom?
Re: SqueezBox Touch
Post by DejanM » 06 Sep 2009, 15:10
To ne znam. Ali to nije ni vazno ... :D A nije vazno jer ti, kao posveceni ljubitelj HiFi, sigurno neces biti zadovoljan ni jednim ni drugim zvukom. Zbog toga ces da kazacis eksterni DAC bez obzira koji od ta dva uzmes. SB je tu u prednosti jer ima i coax i opticki dok ovaj sa tvog linka ima samo opticki izlaz.
Re: SqueezBox Touch
Post by first » 07 Sep 2009, 10:23
Sada pronađoh na net-u da je već poznata i cena za Touch, u USA 300$.
...evo ovde.. http://www.logitech.com/index.cfm/speak ... 5&cl=us,en
To bi u Evropi trebalo da bude oko 300€ što i nije mnogo ako je napravljen kako treba. Ionako već uveliko razmišljam o nekom
samostalnom muzičkom serveru-plejeru koji bi stajao u sistemu, a da mu nije potreban NAS. Ovo se čini kao moguće solidno rešenje. 8)
blood&brain
Re: SqueezBox Touch
Post by blood&brain » 07 Sep 2009, 10:42
DejanM wrote: SB je tu u prednosti jer ima i coax i opticki dok ovaj sa tvog linka ima samo opticki izlaz.
Tri puta sam citao specifikacije i ne videh da ima opticki izlaz? :roll:
BTW, kad smo vec kod tehnickih podataka, nijedan od proizvodjaca ne navodi elementarne cinjenice tipa izoblicenja, odnos signal/sum, nivo izlaznog signala... a ne daj boze da znamo koji integralac koriste u DACu.
Jel' to oni misle
- ili da su dostigli savrsenstvo;
- ili da to nije bitno;
- ili da korisnici njihovih uredjaja to ne bi shvatili;
- ili da ih je jednostavno bas briga? :wb
Re: SqueezBox Touch
Post by DejanM » 07 Sep 2009, 10:54
ovo zadnje ... :D
Inace Squeezebox Duet ima Wolfson DACove ...
blood&brain
Re: SqueezBox Touch
Post by blood&brain » 07 Sep 2009, 11:18
DejanM wrote:ovo zadnje ... :D
Ako je stvarno tako, onda ne mogu nista drugo da im kazem nego "S..... im se na ton-film!"
A da sacekamo da neka ozbiljna firma uzme stvar u svoje ruke i pocne proizvodnju tih sklalamerija?
Recimo, kod WD uredjala me nervira to sto cita samo sa eksternog hard diska. Zasto ga nisu skarabudzili tako da moze da se prihefta i na internet?
U tom slucaju bih se mnogo manje razmisljao da li da ga kupim.
Re: SqueezBox Touch
Post by DejanM » 07 Sep 2009, 12:13
Imas kod Netgear takve sprave - kazu i da nisu lose ... Skuplje su medjutim.
Ovaj WD je jeftin i zgodan je upravo za one kojima ne treba internet, WLAN, ... nego najjednostavnija varijanta: zakacis USB disk i onda WD odatle cita muziku ili film. Problem je naravno napuniti i odrzavati jedan takav disk - moras da ga otkacis od WDa, zakacis za comp, izvrsis spustanje novog materijala pa onda da ga vratis nazad na WD. Medjutim zato WD kosta malo - zbilja malo para ...
Squeezebox ima WLAn i LAN support ali kao sto rekosmo, on podrzava samo muzicke formate ali ne i video ... Pogledaj Netgear ...
LzO
Re: SqueezBox Touch
Post by LzO » 07 Sep 2009, 14:35
Koje? Bilo bi jako dobro da se radi o 8741...
