Zanimljivi sistemi ili komponente
nikolazec
Re: Zanimljivi sistemi ili komponente
Post by nikolazec » 06 Feb 2013, 21:39
sn wrote:Ne moze. kao admin, zabranio sam umiranje za clanove foruma. :wik
E ovo je lepo, da neko i na nas misli =D>
Post by sn » 10 Feb 2013, 18:10
Statement 450 iQ Monoblock Power Amplifier
The Statement iQ power amplifier is the first in a series of VAC components featuring the new VAC iQ Intelligent Continuous Automatic Bias System (patent pending). The VAC iQ System builds on the unprecedented performance of the original Statement Series and takes it to a whole new level with a set of critical enhancements.
The VAC iQ System is the result of 18 years of research and development by the engineers at VAC, and represents the first time in history that each tube in the output stage of a vacuum tube amplifier can be held precisely at the optimal bias point (underlying true quiescent current) at all times, regardless of how loudly or softly the music is playing. The result is sound that is always the best it can be, reduced distortion and noise, longer tube life, elimination of gas current ‘run away’ tubes, and increased reliability, all without any effort by the user. The VAC iQ System also alerts you when a tube is growing weak or has failed. In short, tube drama is a thing of the past.
The Statement iQ power amp also features newly improved output transformers (56 pounds per monoblock!) with smoother, more extended frequency response. The input and driver tubes are now contained on a mass loaded assembly that is specially decoupled from the main chassis for enhanced recovery of ambience and very fine nuance. Input signal handling has been changed to a more pure, direct connection. Various changes to the power supply and chassis materials compliment and support the new circuits.
The VAC iQ Continuous Automatic Bias System is a true breakthrough in power amplifier design. It is not inexpensive, but, once heard, it is indispensable. Add to this the other enhancements, and, to put it mildly, the VAC Statement iQ Series is a very big deal.
:sign http://www.vac-amps.com/productPages/St ... 50_IQ.html
Post by sn » 22 Feb 2013, 22:04
CLARUS
If you're a true audiophile who treasures the finest in audio entertainment - someone who wants to be closer to the original event than ever before possible - the Clarus Collection of audiophile-quality cables from Clarus Sound promises to immerse you in the ultimate listening experience.
Engineered by celebrated cable designer Jay Victor, each of our high-end cables incorporates a host of patented and patent-pending technologies and is constructed of the finest metallurgy and materials - CNC-machined gold-plated connectors, individually insulated interconnect and speaker cable strands, new multi-gauge innovations and precision impedances - complemented by painstakingly meticulous hand craftsmanship.
:sign http://www.claruscable.com/intro.cfm
Clarus - Aqua
Clarus - Aqua
Clarus - Crimson
Clarus - Crimson
Post by sn » 28 Aug 2013, 21:15
Line Magnetic Audio - 805 Integrated Amplifier; 2 x 805 power tubes + 2 x 805 rectifier tubes, 20 watts per channel.
Post by prophet » 28 Aug 2013, 22:08
E to su pravi pojačavači :good
Post by sn » 30 Nov 2013, 13:58
:sign http://www.i-cone.it/eng/
[g2][/g2]
Post by sn » 05 Mar 2014, 19:50
Cypher Labs LLC
Our products showcase reference-level digital-to-analog converters, headphone amplifiers, as well as converter products that deliver high-resolution digital audio to other makes and models of audiophile equipment.
:sign http://www.cypherlabs.com/products/
Post by sn » 04 Apr 2014, 11:47
Blumenstein Audio
Orca Deluxe
The new Orca Deluxe is the result of years of continual development of our compact fullrange speakers, searching for the absolute perfect balance in their performance. The result is speakers that can no longer be referred to as merely "compact."
More intensive applications of our elegant, advanced, yet brutally effective methods of internal bracing on thicker, 3/4" architectural grade bamboo ply (upgraded from 1/2" bamboo ply), and wider, curved baffles give the Orca Deluxe superior control in all frequencies, detailed upper bass, and even clearer high frequencies.
The Deluxe is our "no holds barred," higher horsepower solution for the most demanding listeners. We've been closely monitoring the first pairs we made in our shop since we built them, but from the second we hooked them up, we all stood around and realized that we had come up with something truly special.
:sign http://www.blumensteinaudio.com/orca-deluxe/
Post by sn » 05 Apr 2014, 18:45
Coffman Labs
The Coffman Labs G1-A is a limited edition preamplifier featuring rare and custom parts. It has been created to be a heritage piece—something that will last for decades with proper care.
The G1-A was partly inspired by a century old RCA amplifier. Entirely analog, the antique amp still works perfectly today. (Silicon parts like digital switches and microcontrollers can make the designer’s job easier, but they wear out over time and are very fragile to voltage fluctuations.) Likewise, the G1-A contains nothing that could degrade easily over time. There are no circuit boards: all wiring is point-to-point by hand. The layout is three dimensional so that wire runs are non-existent except for input and output. All of the components are over-sized for voltage, and the switches are military aircraft quality rated for millions of operations.
Over three years were spent selecting the highest grade components and designing this product to their unique specifications. It is truly an original piece, thoroughly infused with the spirit of the golden age analog audio. We believe you will enjoy it for a long time.
:sign http://www.coffmanlabs.com/products-pag ... labs-g1-a/
Post by sn » 19 Apr 2014, 00:55
Liliana
Monoblock Amplifiers
First battery-powered amp to unite high-current MOSFET outputs with our innovative tube stage. Delivers iron-fisted power wrapped in a velvet glove!
At 115 watts RMS per channel into 8-ohms (230 watts RMS per channel into 4-ohms), Liliana Monoblocks drive even power hungry speakers with ease.
But unlike some high-watt amps that may sound flat at moderate volume levels, these monoblocks sound amazing, even at low listening levels. And when you crave “you-are-there” SPLs, Liliana redefines what to expect from a reference-level amplifier. ...
:sign http://redwineaudio.com/components/liliana-re
Post by sn » 26 Apr 2014, 14:22
Sadurni Acoustics
Our horns are made from layered MDF with thickness up to 3 inches. Our favored profile is Tactrix which we find bring more tone and openness to the delicate mid range frequencies.
The lower midrange horn is 92 cm in diameter and will achieve 100 hertz in room frequency response; room dependant. We find this frequency to bring the best sound attributes, most fundamental frequencies of the voice response fit into this range, so a fullness of voice and most other instruments is achieved with it. Careful steps were taken to assure the output of this combination of driver and horn, given a specific loading, to be perfectly matched to the compression driver and tweeter allowing us to get rid of resistors anywhere on our circuit. Another big advantage sprung from the design of this horn is its decay, the natural roll of is in perfect combination with our next channel, allowing for a simpler crossing circuit bringing a more direct response and detailed sound of this most important range.
Our turbine horn gets its name from the aerodynamic shape that has been designed into it in order to make it most transparent acoustically to the surrounding channels for better imaging. This shape also allow us to move the horn back and forward flat on top of our acoustical support, leaving open all possibilities for time alignment, which is so important for a perfect reproduction of the recorded material.
:sign http://www.sadurniacoustics.com/horns.html
Post by sn » 30 Apr 2014, 22:59
SD 710 DAC
SD 710 digital to analog parts are alike the SC 710 CD-player. It offers natural, deep, open but detailed sound reproduction.
SD710 has three coaxial S/PDIF-inputs and three optical TOSLINK-inputs. Outputs are both unbalanced with RCA-connectors and balanced with XLR-connectors
The DAC core is built around Burr-Brown 1792A circuit. Filtering has been made with good-sounding NE5532, and they have been implemented without any loops on the signal path. In other words, without negative feedback. This combination makes SD 710 DAC standing out from the crowd, with the sound quality that was not possible before SoulNote.
:sign http://www.nipponhifi.com/page/products
Post by sn » 01 May 2014, 20:47
Franco Serblin
"I have always loved small speakers, for their discreet presence, for their suitability in less critical
environments, for the “magic” which they often are able to create in music reproduction.
With "Accordo", I followed design patterns that are particularly dear to me. A sound,
a voice capable of reaching the depths of the soul... "
:sign http://www.francoserblin.it/home.php?lang=e
Post by DejanM » 02 May 2014, 07:32
Ovo je tako dobro izdizajnirano da nije ni vazno kako svira ...
Post by sn » 04 May 2014, 13:28
EVOLUTION Series
700i Integrated Amplifier
The MOON 700i is the ultimate Integrated Amplifier. Intended to meet the needs of the most demanding music connoisseurs, it is fully differential dual-mono design, rated at 175 watts/channel into 8Ω, offering authority, finesse and superb control. Using a variety of new technologies developed since the introduction of the Evolution Series, the 700i provides more sonic transparency and accuracy than previously thought possible. In addition, this integrated offers extreme flexiblity while exuding a luxurious presence in any environment.
:sign http://www.simaudio.com/moon700i.htm
