Zanimljivi sistemi ili komponente
Re: Zanimljivi sistemi ili komponente
Post by sn » 11 May 2014, 01:12
PS Audio - DirectStream DAC
Pure DSD done right
"Introducing DirectStream, one of the most remarkable DACS ever built. Hand written, discrete, perfection based conversion that uncovers all the missing information hiding in your digital audio media for all these years. CD’s, downloads, high-resolution PCM or DSD based media are expertly upsampled in the DirectStream to ten times DSD rate and output as pure analog directly into your amplifier or preamplifier. Classic PCM based DACS, including many of today’s DACS that can also process DSD, tend to cover up some of the subtle musical details buried deep within digital audio music; a problem inherent in their architecture. DirectStream solves this problem by employing a pure DSD single-bit approach for both PCM as well as DSD media. This means that your entire library of music can finally reveal all the music and subtle low level details buried deep within its core. Imagine going to a recording studio and listening to a master tape of any recording made. This is the experience DirectStream provides its owners who enjoy a renewed sense of enjoyment and discovery when listening to everything in their library: CD’s, downloads, DSD."
:sign http://www.psaudio.com/directstream-dac/
Post by sn » 14 May 2014, 00:49
Nimis Limited Edition 20W integrated stereo amplifier
"The Nimis was introduced to the Hi-Fi World in 1996 and went on to become a huge success with the public and press alike, even earning itself a place in "Sound Design" by Mitchell Beazley.
Now after a decade of triumph we are proud to present the Nimis LE. The Limited Edition version is achieved by refining our engineering and by hand matching the specially selected components under a strict quality control. Golden plated knobs, transformer covers and ceramic sockets distinguishes this finest version from the legendary Nimis. This extra attention is characterised by our custom made power supply, this features more than double the energy giving each channels pair of EL84/6BQ5 a glorious 20 Watts of push pull output.
Produced in a strictly limited run of 499 units each one is uniquely numbered with a certificate of quality and authenticity. The Nimis Limited Edition 10th Anniversary version is completely handcrafted in Italy as only Synthesis know how. "
:sign http://www.synthesis.co.it/prime-nimis-le.php
Post by sn » 16 May 2014, 01:36
Xs Preamp
"With the Xs we start with a clean slate because the Xs line is of course new.
It is a large two chassis preamp built in a true dual mono arrangement. The circuit board materials are optimized for performance in each area, a power supply circuit board has different requirements than a gain stage and we use different types optimized for their specific uses.
Each channel has its own power supply board with 100,000 uf of capacitors combining several kinds for optimum performance from high reliability electrolytics to custom polypropylene. The use of newly available silicon carbide semiconductors kicks performance up a bit by dropping noise below the level of the XP30.
The gain stages from input to output connectors and all parts between them have been chosen for maximum sonic performance. We use a DC coupled ultra symmetric gain path with high bias class A circuitry. The power supply has lower noise with a refined circuit design and layout. New gain stages with auto bias and DC compensation keep performance at prime.
But it all comes down to the sound. When you go through the door that is the Xs preamp there is no going back."
:sign https://passlabs.com/products/preamplif ... /xs-preamp
Post by sn » 18 May 2014, 01:31
Q&A: Larry Pexton – Triad Speakers CEO Evolves into an Industry Leader
"SHANNON BECKER: How and why did you start your company, Triad Speakers (http://www.triadspeakers.com)
LARRY PEXTON: Triad grew out of Aspen Recreational Products, which manufactured a pre-Walkman cassette player designed for skiing. It was called the Aspen Audiopac. We sold about 5,000 of them before massive Asian competition to the Walkman destroyed the price point we addressed.
The Triad idea was conceived in January 1981 at the Consumer Electronics Show (CES) at the Rotunda Bar at the Las Vegas Convention Center (the bar is now long gone). Hari Matsuda, a very capable industrial designer from Chicago, IL, developed the original Triad Speaker System industrial design. Edward M. Long (speakers) and Ron Wickersham (amplifiers), helped shape the original Triad System with a 10-W amplifier in the woofer.  ..."
source: audioxpress
"Triad’s CinemaReference products were designed for home cinema and music systems that demand high sound pressure levels (SPLs) and audiophile sound quality. This Triad CinemaReference LCR is shown with a zebra wood finish."
Post by sn » 23 May 2014, 20:23
Tuvie
OMNI Futuristic Sound Speaker Concept Will Enhance Your Music Experience
"The unique design of OMNI sound speaker concept will let you always be inside a sound stage, even when you are moving around your living room. With the world renowned brand name ALTEC LANSING, this omni-directional speaker will let you experience the completeness of sound. This heavily constructed futuristic speaker system has less structure vibrations and advanced sound quality. The system incorporates one woofer, one mid-range speaker and tweeter on the top, and all these components are separated from each other through using a ceramic plate. OMNI will not only offer you enhanced music experience, also the décor of the interior of your house will become more alluring."
:sign http://www.tuvie.com/omni-futuristic-so ... xperience/
Post by sn » 03 Jun 2014, 14:38
Invicta Mirus
"Our top-of-the-line product an outstanding DAC for the ultimate in performance. MIRUS uses a dedicated SABRE 32 (ESS9018) per channel: eight DACs in parallel to each stereo channel. USB Audio 2.0/1.0, DSD over USB, SPDIF and the unique SDCard reader are provided. The SDCard supports WAV, AIFF, FLAC and DSD files. Mirus supports input data rates up to 384kS/s and features advanced Resonessence filters."
:sign http://resonessencelabs.com/about-mirus/
What is LIO?
Post by sn » 25 Mar 2015, 21:41
LIO is an audio system platform you can configure, upgrade and evolve to fulfill your changing audio needs. LIO’s user replaceable Performance Modules include a phono preamp, tube linestage, DSD/PCM DAC, power amplifier, and headphone amplifier. LIO is any one of these components, or all of them, and so much more. Discover LIO – the refreshing new concept in high performance audio electronics.
LIO is a new high-end audio component that takes a refreshing approach to separate itself from its competition in two primary ways:
- The death of obsolescence, the rebirth of lasting value. LIO is a modular system that gives you the ability to add features and upgrades at any time. It is designed for long-term ownership, with the ability to easily configure it for your current and future needs.
- Absolutely no noise. LIO includes an all-new, patent-pending power supply design that completely isolates all audio circuitry from the AC mains power at all times. You don’t need expensive power filters, power cords, or conditioners to achieve ultimate in musical resolution.
:sign http://vinnierossi.com/
Post by sn » 18 Apr 2015, 15:04
Adagio 300B
Adagio 300B is a variant of Adagio integrated amplifier. They differ in output tubes, output transformers and heating voltage for output tube, which results in the quality of Adagio amplifiers with 8W of output power.
300B vacuum tube is one of the most wanted tube for all audiophiles and warm of the Single End sound is unbeatable.
:sign http://aurisaudio.rs/en/products/integr ... dagio-300b
Post by sn » 13 May 2015, 20:19
Zodiac Platinum DSD DAC
"The Zodiac Platinum DSD D/A converter takes audio to a new level, offering the audiophile community the most comprehensive, top-end DSD and PCM sample rate support, and most uncompromising quality available in a DAC, complete with 2nd generation Voltikus PSU and a 10 Mhz input for the legendary Antelope 10M Rubidium atomic clock."
:sign http://www.antelopeaudio.com/en/product ... -Converter
Post by sn » 18 Oct 2016, 12:25
September 13, 2016
McIntosh releases MHA150 Headphone Amplifier
"The MHA150 Headphone Amplifier is a worthy successor to the critically-acclaimed MHA100. The MHA150 contains the same feature set and performance standards but adds our new 2nd generation digital-to-analog converter (DAC) that provides support for DSD and DXD files to give you access to the latest in digital music.
Like the MHA100, the MHA150 continues to take advantage of unique McIntosh technologies to create the best possible personal listening experience regardless of the headphones you use. Our Autoformer technology found in our large mono and stereo amplifiers has been adapted to produce three headphone impedance ranges of 8-40, 40-150 and 150-600 ohms so that every headphone will receive the legendary McIntosh sound quality and performance.
For enjoying DSD and DXD files, the USB input accepts PCM signals up to 32-bit/384kHz and supports DSD64, DSD128 and DSD256 along with DXD 352.8kHz and DXD 384kHz. Our proprietary MCT input has also been added to the MHA150; when paired with the MCT450 SACD/CD Transport​, it offers a secure DSD connection for playback of the high definition audio on SACDs." . . .
:sign http://www.mcintoshlabs.com/us/Products ... tId=MHA150
Luxman L-507UX integrated amplifier
Post by sn » 20 Jan 2017, 14:18
Luxman is pleased to announce the L-507uX this merger of transistor amplifier, the 4th version of the highly rated X series, with a high output power of 110W(8Ω) 220W(4Ω). The L-507uX integrated amplifier introduces Luxman electronically control attenuator LECUA, with an illuminated central oriented VU meter on its solid, symmetrical facia, also includes the Luxman exclusive super sound quality feedback circuit ODNF high S/N version 3.0,while keeping all the superb features of Luxman products made in Japan.
The first L-507-s introduced in 1996, since 16 years, has experienced three times the model after the change, L-507uX as Luxman's new model, with great sales by many users support, belonging to L-500 series full of the latest change model.
:sign http://www.luxman.com/product.php?pid=6
Post by sn » 28 Oct 2017, 13:19
Stones Speakers
:sign http://www.stonesspeakers.it/index.htm
B&W 800 Series
Post by sn » 05 Nov 2017, 15:18
Post by sn » 16 Dec 2017, 14:54
LM-805IA INTEGRATED TUBE AMPLIFIER - SINGLE ENDED 805 - 2X48W
:sign https://www.line-magnetic.eu/en/product ... 48w-detail
Post by sn » 31 Dec 2017, 10:11
Dipole hi-end open baffle speakers “Daydream”
Tri-band system with two 15 “bass drivers, six mid range drivers and one ribbon high-frequency driver.
Sensitivity 91dB/2.83V, Nominal impedance 4Ω, Frequency response 34Hz – 34kHz by 0, -3dB, 21Hz-54kHz by 0,-10dB. Maximum power handling – 250W.
:sign http://ecobox.zone/products/speakers/
