Leak - the first name in High Fidelity since 1934
Gramofoni, kablovi, slušalice, tjuneri, magnetofoni, kasetofoni, dodaci..
sn
Forum Admin
Forum Admin
Contact:
Post by sn » 21 Oct 2011, 18:21
:sign http://www.44bx.com/leak/index.html
The Leak TL/12 "Point One" Amplifier
Introduction
The Leak TL/12 was introduced in December 1948, and therefore celebrates its 50'th anniversary in December 1998.
For those not familiar with the Leak TL/12, it is:
An audio power amplifier.
Output is 12 Watts at 0.1% distortion
Was acclaimed at the time to be Britains Best audio amplifier, and is highly sought-after today by high-end audio enthusiasts all over the world.
[g2][/g2]
RIVIERA
Re: Leak - the first name in High Fidelity since 1934
Post by RIVIERA » 29 Oct 2011, 09:46
Kako dobro izgleda taj leak, kao apoteka :yhi
RIVIERA
Post by RIVIERA » 29 Oct 2011, 09:59
primecujem znacajnu slicnost izmedju Leak TL/12 i Quad II pojacavaca
barm u napajanju i izlaznom stepenu donekle...
ono gde je razlika je ulazni stepen i obrtac faze a to je jako vazan deo PP apova uopste
kod quiada to radi perfektno
Za Quad II je navedeno da je to ultralinear koncept izlaznog stepena, dok kod Leak TL/12
za tu opciju postoji mogucnost ugradnjom jednostavnog preklopnika,
posto ako je kao sto je naznaceno na shemi,
OT ima izvode za UL mod...
http://www.44bx.com/leak/Leak/tl12_cct.gif
http://drtube.com/schematics/quad/quad-ii.gif
RIVIERA
Post by RIVIERA » 29 Oct 2011, 10:01
Cak su im isheme nacrtane lepo sa smekom... :nic
Post by DejanM » 29 Oct 2011, 11:32
Glavna razlika izmedju Quad i Leak designa se sastoji u vrsti povratne sprege na izlazu. Walker je izmislio novi tip tzv. katodne povratne sprege, koja ima dosta prednosti narocito u odnosu na klasicnu globalnu povratnu spregu kakvu koristi Leak. Taj izum Walkera je usao u istoriju a vrlo brzo su usledile i McIntosh i Audio Research varijacije na temu. To se sve desavalo tamo negde sredinom pedesetih proslog veka...
