Pioneer PL-L1000
Pioneer PL-L1000
Post by sn » 06 Jan 2012, 18:50
Pre neki dan mi je dosao ovaj matorac na 'pretres', da se malo dotera i utegne, ne bi li jos koju godinu odsvirao..
Bice uskoro jos po neka slika iznutra kad budem poceo da ga cerupam.. :)
TURNTABLE
Motors : 1x Direct-Induction linear motor (tangential tracking)
1x Stable Hanging Rotor motor (platter)
1x ancilliary DC motor (arm cueing)
Platter : 31cm, Die-Cast aluminium
Inertial mass : 330kg/cm2 (incl. rubber mat)
Speeds : 33 1/3 & 45rpm
Wow & Flutter : < 0,025% (WRMS) ; < 0,013% (WRMS, measured at FG output)
S/N ratio : > 78dB (DIN-B)
ROTATIONAL
Build-up time : within 90° at 33 1/3 rpm
Speed deviation : < 0,002%
Speed vs load : stable up to 220g drag load
Speed drift : < 0,00008% per hour at 33 1/3rpm ; < 0,00003% per temp degree change at 33 1/3rpm.
TONEARM
Type : linear-motor direct-drive, static-balanced, tangential tracking
Effective length : 190mm
Overhang : 0mm
Resonance : 6,5Hz
Cartridge weight : 4g...14g ; 14g...23g with aux. weight
Arm height adjustement : ± 3mm
FEATURES
• Fully Automatic
• Direct-readout counterweight
• Quick-start/stop
• Arm height adjusting device
• Electronic cueing device
• Arm clamper
• Spirit level
Semi Conductors
• 23 ICs
• 14 transistors
• 18 diodes
• 3 Hall elements
• 14 LEDs
• 5 photo transistors
• 1 CdS
GENERAL
PC : 35W
Dimensions : 49,4 x 15,4 x 45,6cm
Weight : 12kg.
[g2][/g2]
Re: Pioneer PL-L1000
Post by PrekoBare » 06 Jan 2012, 23:36
Au, pa to je lepota !!! Evo jedne prigodne da zasvira:
...uz'o beges pod svoj ajer naglanco ga ko fijaker(2x)
Skinuo mu staru zicu
promenio kobilicu
namazo mu sve civije
pa se beges samo smije
(2x)
A sta vam je ljudi moji
to je beges, Bog Bogova
jos kad dodje u ruke prave
dobre su i zice stare
I sad Steva cuva beges
miluje ga ko devojku
jos kad neko sale radi
metne banku ili stotku
Pa da vidis moj djerdane
svira beges dok ne svane
Post by sn » 06 Jan 2012, 23:56
:-({|= :D
eto, covek u praznicnom raspolozenju!
Sretni ti praznici PrekoBare!
Post by PrekoBare » 07 Jan 2012, 23:34
sn wrote:Image
Ako ces vec da ga otvaras, porazmisli o opciji da mu izmestis trafo napolje. Vrlo jeftino resenje a moze da mu digne kvalitet ohoho jer ce da ukloni izvor unutrasnjih vibracija. Takodje, vidi sta unutra moze da se ponasa kao rezonator pa premazi onim auto namazom za vrata. Ja sam kod mog technicsa skinuo plasticnu "radkapnu" ispod tanjira koja se ponasala kao membrana i pojacavala vibracije.
Post by sn » 08 Jan 2012, 01:07
Chovek koji mi je doneo ovaj gramofon ne zeli nikakve akcije van njega, vec samo da se popravi par stvari i dotera malo.
Sto se mene tice kad bih ga pakovao za sebe, bilo bi tu jos nekoliko akcija osim tog trafoa;
Opruge su vremenom sabijene, ne mogu vecito da se natezu, znaci morale bi da se zamene ili sprenguju; gumene caure u kojima se nalaze su vec ispucale i trebalo bi nove staviti; 'kolica' koja nose rucku treba ocistiti i podmazati lezajeve na njima, i jos nekoliko stvari. Ono sto je najveci minus kod ovog modela (ako bi razmisljali o nekoj ozbiljnijoj modifikaciji) je to sto je ceo motor sa tanjirom na sebi pricvrscen (usrafljen) na donju plasticnu sasiju, koja ima neka rebrasta ojacanja ali za tu tezinu nedovoljno, tako da tu ima i vibracija i uvijanja i tu bih stavio neko ukrucenje a posle dampirao gde treba. Trafo je zasrafljen za gornji deo koji je fiksan i oslanja se direktno na nogice, dok je donji plivajuci na kome je motor, elektronika i linear motor sa ruckom. Sve u svemu baza ovog gramofona i nije za neke ozbiljnije modifikacije i ulaganja veca od ovog, neki drugi modeli su pogodniji za to, ovo je ipak samo jedan stari dobar gramofon..
Post by sn » 09 Jan 2012, 21:55
.. i kako sve to unutra izgleda;
Jedini ozbiljniji kvar je bio sto je ispala iz lezista zadnja sina po kojoj idu kolica sa ruckom koja su zato upala unutra, ali to se lako vrati na mesto i stegne sa imbusom. Zamenjena je i gumica na motoru za lift, jer se vremenom deformisala. Ostalo je bilo ciscenje, podmazivanje i podesavanje.
Post by DejanM » 09 Jan 2012, 22:10
Izgleda kao nov. Odlican rad, sn ... cestitke ... :good
