Kazetofon (prijedlozi)
Staromodan
Post by Staromodan » 14 Jun 2012, 19:23
Hoćete li predložiti kazetofone koji imaju prirodan i neutralan zvuk, s ručnim namještanjem biasa za svaki kanal posebno, a da nisu komplicirane izrade?
Re: Kazetofon (prijedlozi)
Post by sn » 14 Jun 2012, 20:26
TEAC C-3RX
C-3
3-Heads
IC Logic "touch-control" transport
Rack-Mountable
Dolby NR built-in with DBX optional ports on rear
Tape Type selector for Normal, CrO2 & Metal
Tape EQ selector for Normal, CrO2 & Metal
Auto-Stop
RCA and DIN I/O's
Dual Analog VU signal level meters
Dual record level controls
Selector for "Preset Record / Bias" or "User" levels
Dual Front Panel-Internal Bias controls
Dual Front Panel-Internal record level controls
Timer Play / Record / Off selector
Memory Stop / Play for counter
DBX Send / Receive loops via RCA's on rear panel as well as Control Signal Port
Port for optional RC-90 remote control (not included)
Dual front mounted 1/4" mic input jacks
Front mounted 1/4", Stereo Headphone jack
C-3RX
Same characteristics plus remote control unit and DBX pilot lamp.
Two tape speed : 4.8cm/s - 9.5cm/s
Unit sold with handles.
Wow & Flutter :
WRMS 0.04% (4.8cm/s)
WRMS 0.03% (9.5cm/s)
Frequency response (4.8cm/s) :
20Hz to 20kHz (metal tape)
20Hz to 19kHz (chrome tape)
20Hz to 16kHz (normal tape)
Frequency response (9.5cm/s) :
20Hz to 25kHz (metal tape)
20Hz to 24kHz (chrome tape)
20Hz to 21kHz (normal tape)
S/N ratio :
metal tape 60dB (4.8cm/s) / 62dB (9.5cm/s)
Using Dolby NR: +5 dB (1kHz), +10dB (more than 5kHz)
Input
Mic: At least 0.25 mV/200 Ω (-72 dB)
Line: 60 mV/50k Ω
Output
Line: more than 0.3 V/50k Ω
Headphone: 8 Ω
Power consumption 25 w
Dimensions 482 × 147 × 345 mm
Weight 9,5 kg
POWER 50 / 60 cycles and a voltage selector for AC input (120v, 220v, 240v).
teac_c-3rx.pdf
Service manual
(4.18 MiB) Downloaded 47 times
teac_c-3rx.pdf
Service manual
Post by PrekoBare » 14 Jun 2012, 20:47
Kad je kasetofon u pitanju, primarni izbor je Nakamichi.
Tajna nakamichija je u specijalnoj izradi glave za snimanje, nesto sto drugi nisu imali. Tako da i Nak oskudnih funkcija naprosto
"odere" vrlo komplikovane uredjaje konkurencije koji jednostavno ne zvuce dobro. Nak-u ne treba ni Dolby S ni Hx-pro da bi zvucao kako treba.
Koji Nakamichi, zavisi od para koje su na raspolaganju. Mogao bih da preporucim sledece:
Za manje para:
Nak 600 - jeftina dvoglava masina, kad se remontuje radi kao najbolji uredjaji konkurencije
Nak LX5 i BX300 = jeftinija varijacija na skuplju ZX temu. BX300 je u japanu prodavan kao ZX5
Za vise para: ZX7, ZX9, CR5, CR7
ZX serija uglavnom zahteva kompletnu zamenu kondenzatora (guglaj orange drop disease Nakamichi)
sto zahteva ili mnogo truda ili dosta para.
Dragon NE preporucujem.
Od drugih proizvodjaca, SONY ES gornji modeli i Pioneer CT-95.
Ako su pare problem, bolje sacekati malo nego kupovati kojesta na brzinu.
Staromodan
Post by Staromodan » 15 Jun 2012, 16:37
Hvala na odgovorima.
Post by RIVIERA » 25 Jul 2012, 11:54
