SL-1200 Upgrades: Sound HiFi
Post by sn » 30 Apr 2014, 21:02
From the beginning
My journey in HiFi started with a Technics SL1200 about 35 years ago, yet I quickly got caught up in being a proper audiophile trading that table in for a belt-drive Rega Planar 3. To be fair to the Rega, I still prefer the sound of a P3 to the sound of a stock Technics SL-1200, which I find rather dark and cloudy sounding overall. Careful attention to detail when setting up an SL-1200 will wring every bit of resolution for which it is capable, but this is still not a ton.
The good news is that Technics has been building the SL-1200 for a long time and the core turntable mechanism (motor, base and platter) is robustly built. The direct-drive mechanism has a lot of torque and the table has a very weighty presentation with a fair amount of bass detail despite its other shortcomings. While a basic “audiophile approved” turntable can easily run a couple thousand dollars without a tonearm, you can still find a like – new SL-1200 on the secondary market for $400 -$500 (in the U.S. anyway), so this is an excellent platform for modification. Think of the SL-1200 as the Volkswagen GTI of the turntable world.
I’ve investigated the KAB series of modifications for the SL-1200, and they have ultimately left me cold because I still feel that the stock SL-1200 arm is the weak link in the equation. The full suite of KAB mods certainly improve the SL-1200, the minute I drop a record on a Rega P5, or a nice used Linn LP-12, I’m still not that interested in the Technics. ...
:sign http://www.tonepublications.com/analoga ... ound-hifi/
Re: SL-1200 Upgrades: Sound HiFi
Post by PrekoBare » 02 May 2014, 17:42
ja sam nabuzio mog tehniksa bolje i jeftinije nego sto ova ekipa okupljenoa oko sound hifi i the art of sound predlaze . Stos je u tome da se nadju delovi sto jeftinije online.
Recimo okrugla ploca za montazu rucke ("board") moze da se kupi za 30 ili za 90 funti, isti kvalitet. Ista nova rucka moze da kosta vrlo razlicito zavisno odakle se narucuje.
1. poskidao sve plasticne delove ispod tanjira - besplatno
2. promenio nozice - stavio isonoe
3. promenio rucku - Jelco 750D, custom drzac za rucku i ploca za montazu.
Sledeci korak ce mi biti da izbacim trafo i koristim regulisani napon od 19v.
Post by DejanM » 02 May 2014, 18:56
Na koji trafo mislis ?
Post by sn » 02 May 2014, 19:17
Trafo iz njega..
Post by DejanM » 02 May 2014, 19:25
Je li to trafo za napajanje ili je neki razdvojni trafo ?
Post by sn » 02 May 2014, 19:39
originalni trafo za napajanje.
Post by PrekoBare » 02 May 2014, 19:45
Post by DejanM » 02 May 2014, 20:30
Ako sam dobro razumeo Prekobare zeli da izbaci trafo koji se nalazi u samoj sasiji gramofona, i originalni PSU i da napravi nov, regulisani DC od 19V koji bi se nalazio van sasije gramofona ?
Post by sn » 02 May 2014, 20:45
Da.
Mada se ne bih slozio po pitanju nekih stvari.. nisam bas duboko ulazio u tekst sa ovog linka, ali kolko vidim oni taj napon (koji je inace u originalu 21V)
.. stabilisu sa LT(M)317 sto je po snazi (1,5A) prilicno slabije od originalnog tranzistora 2SD1265 koji je 4A 30W..
Post by PrekoBare » 03 May 2014, 05:37
Dejane, novi trafo sam vec nabavio, NEMIC LAMBDA, sa regulisanim naponom. Izraelski vojni visak. Izvinjavam se, daje 21V a ne 19V.
Blue Circle radi nesto slicno, s tim sto na mesto izvadjenog trafoa stavljaju dva kondenzatora.
Post by DejanM » 03 May 2014, 10:09
PrekoBare,
Ja ne bih menjao originalno napajanje sa LM317 bas zbog toga sto si rekao: LM317 ne daje 4A. A ogranicavati struju na 1,5 A - to zavisi naravno od toga da li potrosac moze da radi dobro i sa tom strujom. Ali ako je vec bilo projektovano na 4A - verovatno da ne.
Zamena trafoa ima smisla ako si nasao neki bolji (i znas da je bolji). Uklanjanje trafoa i stavljanje kondenzatora mi se takodje ne cini bas kao neka dobra ideja.
Ako zelis bas da napravis ekstrni PSU i da ga uklonis iz same sasije gramofona, ja bih ti savetovao da onda ides po regulisano napajanje pomocu nekog dobrog shunt regulatora. Ima ih dosta na trzistu ali na zalost malo ih je zbilja dobrih. Pokusaj recimo sa Bellenson - oni nemaju regulator od 21V i 4A u standardnoj ponudi ali su mozda spremni da naprave takav. (Jeftinija) Alternativa ti je da ides sa novim LM338, koji moze da regulise do 5A. To radi dobro i mozda nije tako dobar kao Bellenson, ali je dobra opcija. Ovde imas datasheet za LM138/338:
http://www.ti.com.cn/cn/lit/ds/symlink/lm138.pdf
Ono sto jos mozes da uradis jeste da stavis jedan X1 kondenzator na sekundaru, izmedju nule i faze a ispred dioda. Njegova vrednost moze da bude 0,47 uF. To bi moglo da ima odredjenog efekta. Ono sto se jos radi jeste da se stavi i razdvojni trafo ispred ovog trafoa koji obara napon mreze. To su 1:1 trafoi koji medjutim obicno dosta dobro ciste HF djubre iz mreze i zapravo sluze kao filteri. Trebalo bi da su dobri, torusni tzv. medicinski, Amplimo razdvojni trafoi - ali sa njima nemam nikakvog iskustva. Ja sam koristio Lundahl LL1655 i sa njim imam odlicno iskustvo ali on ne moze da da 4A (ima 300VA). A Lundahl ne pravi vece razdvojne trafoe, tako da ta opcija otpada.
Ako stavis PSU u neku eksternu kutiju, obrati paznju i na konektore. Stavi nesto iz profi ponude, nesto sto ce imati bakarne kontakte i sto stoji cvrsto. Ja sam jednom koristio za prenos DC obicni RCA konektor i onda napravio obican kabl sa RCA konektorima - i to je bila losa ideja.
Post by DejanM » 03 May 2014, 14:48
Ispravka: nije Bellenson nego Belleson:
http://www.belleson.com/
Post by sn » 03 May 2014, 20:39
eee, lako je vama kad ne morate da se bakcete sa reparacijom komplikovanijih elektro-mehanickih naprava... :)
Post by PrekoBare » 05 May 2014, 20:10
DejanM wrote:PrekoBare,
Dejane, hvala za savete. U poslednje vreme sam se nesto umorio, ostavljam za drugi put. Stavicu na sigurno mesto kad jednog dana najzad resim da to uradim.
Mislio sam da koristim Neutrik konektore za stuju. A narocito ti hvala za ideju za razdelni trafo, jer laboratorijske POWERWAR razdelne trafoe mogu lako da nadjem za male pare. (Koristim vec jedan od 1.2 KW).
Post by PrekoBare » 05 May 2014, 20:21
sn wrote:eee, lako je vama kad ne morate da se bakcete sa reparacijom komplikovanijih elektro-mehanickih naprava... :)
sto jes' jes. Mnoge dekove su pravili ko da ih nikad niko vise nece servisirati.
Ne znam kakva je ta hiljadarka unutra, ali ako je kao CT-F1250 nije ti lako - kod njega je zamenu najobicnijeg pogonskog remena moralo sve zivo da se odlemi, kao da je lud covek projektovao.
