Ashly Audio
Ashly Audio
Post by sn » 23 Sep 2012, 13:55
3.6SP / 4.8SP Protea™ Speaker Processors
This live performance legacy continues with our high performance analog signal processing equipment and the new 3.6SP and 4.8SP Protea™ Speaker Processors. The 3.6SP (3-in × 6-out) and 4.8SP (you guessed it…4-in × 8-out) offer front panel or computer control of your audio system.
Ashly's Protea™ Digital Speaker Processors deliver premium sonic performance with an intuitive and user-friendly software platform. The 3.6SP (3-in x 6-out) and 4.8SP (you guessed it…4-in x 8-out) are a great choice for both live sound and use in fixed installations like worship facilities, schools and performance spaces.
The SP-series has front panel controls for immediate access to the settings during a dynamic, live performance. The front & rear panel USB ports allow you to program the DSP via Ashly's Protea™ software – and set a password-secured security system to prevent unauthorized tampering.
Use the full Protea™ DSP suite – crossover, equalization, compressor/limiter & delay. With up to 682ms on the input and the output, the SP-series can serve as a front-end processor for delay stacks. The three inputs on the 3.6SP give you added flexibility, particularly when most other processors only offer two inputs.
:sign http://www.ashly.com/
Data Sheet:
Protea 3.6SP: http://www.ashly.com/Resources/Document ... t/36sp.pdf
Protea 4.8SP: http://www.ashly.com/Resources/Document ... t/48sp.pdf
[g2][/g2]
