Yamaha RX-V3800
Prodaja uredjaja, komponenata.. | #prodajem
Forum rules
Važno u vezi Oglasa - Ako ste prodali uredjaj, napišite 'Prodato' u zadnjem postu i zaključajte temu.
Mellow
Nov korisnik
Nov korisnik
Yamaha RX-V3800
Post by Mellow » 27 Dec 2011, 14:53
Kupljen u decembru 2009 u 4audiju. Sto bi rekli u mint stanju (sve vreme stajao na jednom mestu).
U vreme kupovine najbolji i najskuplji model risivera Yamahe.
Ful pakovanje (kutija, uputstvo, mikrofon, dva daljinska, antena).
Specifikacije:
7.1-channel surround sound receiver
140-watts minimum continuous power per channel, 8 ohm loads, two channels driven from 20Hz-20kHz with a maximum total harmonic distortion of 0.04%
Analog audio input sensitivity and impedance: 200mV, 47kohms (line), 3.5mV, 47kohms (phono MM)
Analog output level/impedance: 200mV/900 ohms (REC Out)
Speaker impedance: 6 ohms-16 ohms
Analog audio inputs: Ten L/R (line), L/R phono (MM), 5.1-channel analog
Digital audio inputs: Three coaxial, four TosLink optical
Analog audio outputs: Four L/R (2xL/R record, L/R Zone1, L/R Zone2, L/R Zone 3), one 7.1-channel preamp out, headphones, Eleven pair speaker terminals
Digital output: One TosLink optical
Video inputs: Seven composite or S-video, three component, four HDMI
Video outputs: Two composite or S-video, one composite-only zone 2, one component, one HDMI
Other: Setup microphone, two 12V trigger, RS 232, IR in/out, IEC power connection, antenna (AM/FM/ XM), iPod Dock input
Dimensions: 17-1/8" x 6-3/4" x 17-1/4" (W x H x D)
Risiver moze da se poslusa kod mene pre kupovine.
Tel 064-8353-017.
