Ideal Diode Bridge Controller
Proizvodjači, distributeri, časopisi, linkovi..
Post by sn » 23 May 2014, 17:39
LT4320/LT4320-1 - Ideal Diode Bridge Controller
Features
Maximizes Power Efficiency
Eliminates Thermal Design Problems
DC to 600Hz
9V to 72V Operating Voltage Range
IQ = 1.5mA (Typical)
Maximizes Available Voltage
Available in 8-Lead (3mm × 3mm) DFN, 12-Lead MSOP and 8-Lead PDIP Packages
Typical Application
Description
The LT®4320/LT4320-1 are ideal diode bridge controllers that drive four N-channel MOSFETs, supporting voltage rectification from DC to 600Hz typical. By maximizing available voltage and reducing power dissipation (see thermograph comparison below), the ideal diode bridge simplifies power supply design and reduces power supply cost, especially in low voltage applications.
An ideal diode bridge also eliminates thermal design problems, costly heat sinks, and greatly reduces PC board area. The LT4320’s internal charge pump supports an all- NMOS design, which eliminates larger and more costly PMOS switches. If the power source fails or is shorted, a fast turn-off minimizes reverse current transients.
The LT4320 is designed for DC to 60Hz typical voltage rectification, while the LT4320-1 is designed for DC to 600Hz typical voltage rectification. Higher frequencies of operation are possible depending on MOSFET size and operating load current.
:sign http://www.linear.com/product/LT4320?ut ... nicsWeekly
