Sparko's Labs
Proizvodjači, distributeri, časopisi, linkovi..
Sparko's Labs
Post by sn » 12 Aug 2015, 14:58
Sparko’s Labs has created a family of discrete op amps in an 8 pin DIP compatible package optimized for high performance audio applications. These devices are drop in replacements for many common, yet inferior audio op amps and are uniquely compensated for trouble-free swap out into virtually any circuit. Having a footprint of a mere 0.33 square inches, these devices are one-third the size of any other discrete op amp on the market. Class A biasing and high output current capability coupled with a proprietary compensation scheme requiring multiple NPO dielectric capacitors make these discrete op amps impossible to fabricate as a monolithic IC. These devices utilize matched transistor pairs encapsulated within a single device package for the input stage and internal current mirrors, which retains the advantage that monolithics have with device matching. Each device is fully specified, and is available as a single or dual discrete op amp.
:sign http://sparkoslabs.com/discrete-op-amps/
