SACD i externi DAC
SACD i externi DAC
Post by sdanicic » 16 Jan 2009, 10:01
Koliko se secam ovde na Forumu nije bilo neke price i prenetih iskustava o koriscenju externih DAC-ova i povezivanja CD/SACD/DVD-A ili CD/SACD plejera na isti - ALI SA ZELJOM DA SE DOBIJE ZVUK SA SACD lejera na hibridnim diskovima.
Varijanta plejera i externog DAC-a kada su u pitanju CD, HDCD, XRCD i DVD-A je u redu, ali ako zelite da dobijete zvauk sa SACD lejera preko externog DAC-a, e to bas nece moci. Ovo verovatno znate :-" ali hajde ipak da ponovimo:
Just on the DAC thing, no, you can't use an external DAC for SACD. You can still use it with an SACD player to do the D/A conversion for normal CDs but not SACDs.
The reason is that SACD is:
a) a totally different digital format (DSD bitstream instead of 16/44.1 PCM)
b) encrypted.
There are DACs that will handle DSD bitstream for SACD but not many. The only one I can think of at the moment is the dCS one which costs $$$$. It takes a FireWire input for the SACD signal. Of course you'd need an SACD transport/player that also had the FireWire bitstream digital output, and there aren't many of those either.
The simple answer is you can't use external DACs for SACD at the moment.
I jos nekoliko dovijanja (HDMI, iLink itd.)
http://www.head-fi.org/forums/f7/sacd-e ... be-205319/
http://www.head-fi.org/forums/f7/whats- ... dac-51274/
http://forum.audiogon.com/cgi-bin/fr.pl ... 1228604503
http://www.echoloft.com/hifi-forum/inde ... ic=16906.0
